TestGenerator: FXT is Read-Only Error
Mike Meyer
Re: TestGenerator: FXT is Read-Only Error
That did fix the previous error code but I am now getting an error 32 cannot open.
Could you please send a screenshot of the error including the logs? Is the error occurring if you test with the "MACD Sample" EA?
Mike Meyer
It is being tested with the sample EA
- Capture.PNG (8.96 KiB) Viewed 18138 times
Hi Mike,
As per our discussion offline, I believe everything is working now. Please let us know if you have any further difficulties.
Leaving the FXT files as read only was exactly the fix for me!
I saw the "Error" and removed the read only status. After that, all expert adviser gave different results.
I noticed when the ea was being compiled for back testing, and it was building data, that the window showed using M1 data, although i was specific about M15.
Great Job tickstory team! Well worth the money paid!
Only question i have is, why would you let someone adjust time zone? That seems dangerous.
All data from Dukascopy is in EST time zone, and that shouldn't be changed, correct?
I was able to verify chart to import bar by bar at https://www.dukascopy.com/plugins/fxMar ... rical_data
Again, awesome job!
Again, awesome job!
Hi Qboney,
Thanks for the nice feedback - it is really appreciated!
Regarding time-shifts, not all brokers necessarily have the same time-zone as the source broker. In these cases, it may be preferable for the tests to ensure that the time is in your broker's native time-zone. This means when you finally go live, you shouldn't need to do any changes to your EA's time-shift settings.
