The ConfigFileName can be whatever name you like. Typically Tickstory tries to name the config file based on broker name, however sometimes this gives an invalid filename requiring it to be manually set in the "ConfigFileName" setting. The EA setting you show looks fine. If you don't see the file written to the "files" directory, just check the Journal and it will usually give a reason.
Backtest always stops on a certain date.
Re: Backtest always stops on a certain date.
I found the file and now it works perfectly, thanks
