D1/H4 mismatch
Trader2384
Re: D1/H4 mismatch
Post by Trader2384 »
I don't know if you were replying to my last response but I didn't understand what you meant by "H4 is not producing the same data as before
and certainly doesn't look anything like data from other ECN brokers." Does that mean there is a problem with the dukascopy data - did it change since the beginning of this thread?
Tickroll
Re: D1/H4 mismatch
Post by Tickroll »
Hi Trader2384,
Yes, XAUUSD / H4 / EST +7 / Dukascopy data. I exported with the new 1.4 version, the bar chart looks nothing like the one from a week ago,
I also compared it to several ECN brokers. There is something very wrong, I think it has to do with the Timezone conversion process.
Of course my EA has gone from great profit to zero. Any ideas?
Trader2384
Re: D1/H4 mismatch
I'm not sure, sorry.
Re: D1/H4 mismatch
Hi Tickroll - appreciate if you could detail your issue in a separate thread.
Trader2384 - Could you please confirm the original issue you reported has now been resolved for you?
Trader2384
Re: D1/H4 mismatch
will test it over the next couple days and report back
Trader2384
Re: D1/H4 mismatch
yes, I downloaded new files with the same date range/parameters and issue appears to be fixed.
scfx
Re: D1/H4 mismatch
Post by scfx »
Hi Everyone,
I find Tickstory very helpful with my backtest data. However there are few concern with my experience so far.
I download data with New York close setting, then I compare live chart with .hst generated by tickstory.
1. On H1 chart, tickstory seems to systematically miss the last 2 bars of the week (bar 22:00 and 23:00 Friday of course). Other than that, time of bar are the same between 2 charts.
The other issue on H4 and D1 is already fixed in the updated version! So much thanks to tickstory.
I appreciate it if you could help me solve those issues.
SCFX
Re: D1/H4 mismatch
Hi scfx,
The bars you are missing are probably due to the "Filter weekend" setting being checked. Can you uncheck and see if that resolves your issue?
