Error "executable file is corrupted. Please recompile it."
mkeropian
Re: Error "executable file is corrupted. Please recompile it
Post by mkeropian »
well, i tried to replace the termial.exe from a build 482 mt4 folder, but when i launch the mt4 from tickstory app appears that message... attached image.
help please...
regards
Hi mkeropian,
Firstly ensure your MT4 terminal can be run normally by selecting it from the Windows 'Program' menu. If it runs correctly, then try again to launch the terminal from Tickstory (while MT4 is running).
The launcher has been tested on Build 482 so I'm not sure why you are having an issue. If you continue to have problems after this, I would suggest to roll back to a version you know works and recompile your EA for that version.
