Free tick data available for Amibroker, Ninjatrader and more
Re: Free tick data available for Amibroker, Ninjatrader and
Hi Simonayres,
Do you have a sample of the import file format that Tradestation accepts? Chances are you can design a custom file format with Tickstory that will work.
If it is successful, we can look at adding it as a pre-defined format.
Please let us know.
Hi Simon, As you're aware, we're trading your request for Tradestation integration on this thread:
https://tickstory.com/forum/viewtopic.php?f=5&t=1555
imbissbronko
Post by imbissbronko »
tickstory wrote:Hi,
Exporting to Forex Tester is now supported in v0.9.2. We also added support for Forexsb (http://www.forexsb.com).
How can i export to forexsb ea studio..it must be an json file.
Hi Imbissbronko,
At this stage, the best way to potentially do this at the moment is export the data to a comma-delimited file or Excel spreadsheet and perform a macro to convert it. We've added a note about how we can support a JSON export in the future.
