Errors - Request aborted/Remote name not resolved
huangwh88
Post by huangwh88 »
Hi Tickstory,
I was exporting USDJPY data from 2006 onwards and I got the following errors in the 2009/2010 periods. Please help, thank you.
USDJPY export error
USDJPY export error
tickstory error.png (6.06 KiB) Viewed 9014 times
Re: Errors - Request aborted/Remote name not resolved
Hi Huangwh88,
Looks like you came across some sort of internet connection glitch and/or overload. Tickstory typically automatically recovers from this error by retrying to download the data. The next time you download the same date range the error should no longer appear. If it does, just ensure your connection is stable or, if possible, try a different connection.
huangwh88
Post by huangwh88 »
tickstory wrote:Hi Huangwh88,
Looks like you came across some sort of internet connection glitch and/or overload. Tickstory typically automatically recovers from this error by retrying to download the data. The next time you download the same date range the error should no longer appears. If it does, just ensure your connection is stable or, if possible, try a different connection.
Thank you, I re-downloaded it and there were no errors.
