getting this error - see attached image
suggestions?
mt4 open data error
Re: mt4 open data error
Hi Moss27,
These are not errors but warnings. The system should continue to back-test as per normal.
Still getting errors,
Data quality is n/a
mismatched chart errors
suggestions?
thank you
Data quality is n/a
suggestions?
thank you
Hi Moss27, If you are using the free version you need to roll-back your to MT4 Build 765. Otherwise, if you license your copy you can work with the latest MT4 Build (and also get priority support!)
Is it only build 765?
I am using an older version but still getting errors.
Setting used for 5 digit broker but it looks like data was import error
other issue im getting is volume 1 for all imports
