Period data export using ASK instead of BID
stoneknuckle
Post by stoneknuckle »
Thanks for such a useful and easy-to-use tool.
When exporting data to CSV, it appears to export the OHLC of the BID data. It would be very useful to be able to choose to export the OHLC of the ASK data instead. This is especially helpful since many "reliable" source (i.e. U.S. Fed Reserve) quote the ASK price in official data releases.
Thanks for your consideration.
stoneknuckle
Re: Period data export using ASK instead of BID
Hi stoneknuckle,
This Is a good suggestion and will be added to the list of enhancements.
Kind regards.
