Symbol DAX30
lulipot1
Symbol DAX30
Post by lulipot1 »
Hello
I still use Tickstory Lite version 1.7.4.0
Metatrader Does not work with symbol DAX30
Why?
I see the Name is different Metatrader has GER301.hst
Tickstory format is DEUIDXEUR1.hst
mfg
Raneri
Re: Symbol DAX30
Hi Raneri,
You need to map your symbol from DEUIDXEUR to your MT4 symbol name "DAX30". Please take a moment to refer to the manual about how to "map" your symbols and don't forget there's a wealth of information in the forum if you search for DAX:
search.php?keywords=DAX
