Command Line Download API
tradewave
Post by tradewave »
I am trying to find a way to download tick story data from a Python script. In order to do this I would need to be able to access some sort of an API that would allow me to bypass the Tickstory User Interface and download directly from a command line API. Is this possible with current software ?
If not, this I believe would be a great feature addition.
Thanks,
Andrew.
Re: Command Line Download API
Hi Andrew,
Thanks for your question. At the moment (as of v1.8.8) it is not possible to operate Tickstory via the command-line. We have got this noted, so thank you for your suggestion!
Kind regards.
