Installing on Windows Server 2016
randomfox
Post by randomfox »
Cannot install on windows server 2016.
Trying to run the setup file, but nothing happens
Thanks, RF
Re: Installing on Windows Server 2016
Hi Randomfox,
Can you please ensure that .NET v3.5 is installed on your server (this link may help: http://www.technig.com/install-net-fram ... rver-2016/).
After that, can you please ensure that you are running the setup as Administrator? You may want to check to see if there are other restrictions which are preventing the setup from being run (for eg. virus checkers, Windows restrictions, etc).
If you are still having difficulty, you can manually copy the Program Files folder from another PC.
randomfox
Post by randomfox »
Thanks for your reply.
I have .NET 3.5 installed. Also, i already have 1.8.8 installed without any issue, it's just the new 1.8.9.1 that i have trouble with.
Tried as administrator - no success...
Thanks, RF
randomfox
Post by randomfox »
Just tried now to install on windows 8.
I get the following message:
Windows protected your pc
Windows smartscreen prevented an unrecognized app from starting. etc
Publisher: Unknown Publisher
Maybe that's what preventing it in windows server 2016?
Anyway - i think that this is an issue for windows 8 as well - this warning should not appear
Thanks - RF
randomfox
Post by randomfox »
Have a WA for this.
Did a new download, but extracted the file in windows 8.
then copied the extracted setup file to windows server 2016 - this time the installation was successful
Thanks - RF
Hi Randomfox,
Good to hear that the manual copy worked. It is possible that there is a setting under Windows Server that is preventing the setup from running normally, however you would think it would also apply to the main application file. If you manage to find out more, please let us know. We will be adding signing to our application in a future version which will prevent the warnings you are seeing.
randomfox
Post by randomfox »
Well, i copied the setup file after i unzipped it in windows 8, not the tickstory binary.
So i would rather say that there is an issue with unzipping the file in windows server 2016.
Thanks - RF
