Error in directory MT4 selection
lorydan
Post by lorydan »
I'm trying to put my installation directory but
the system answer with this error:
"Questa non sembra essere una directory di installazione valida.Si prega di accertarsi di aver selezionato la cartella metatrader radice ( es. C:|\\Programmi \\Metatrader) e si è eseguito MT4 almeno una volta prima di selezionare la cartella di installazione"
in my case "cartella metatrader radice" is C:\windows\programm(x86)\forextime MT4 and I'm sure of this.
I'm also sure I have running platform, EA and tester.
Have you any sugestion? Some of you have the same problem? and, if yes how to resolv this?
Re: Error in directory MT4 selection
Hi Lorydan,
Please check out this thread to help resolve the issue:
https://tickstory.com/forum/viewtopic.php?f=4&t=1298
lorydan
Post by lorydan »
I have see the link you give me and:
I make step 1 and it is ok
I make step 2 (run mt4, run ea, run editor, run my ea, run tester at least once on platform mt4)
I'm not in portable mode
I continue have iusse so I put here some screen shots:
scrshooorg= screen shot of my datafolder/origin file
scrshhist= screenshot of my datafolder/history
I can't see the file .sel but this is my problem
seldir=screenshot of my selection
screrr=screenshot of error
lorydan
Post by lorydan »
I have solved!
the problem was: it needs an account logged in !
Hi Lorydan,
Good to hear it's solved. Correct - as mentioned in the instructions, you need to connect to your broker/log in to ensure all important files are downloaded. Once this is done, Tickstory will have the files it needs to recognize it as a valid MT4 path.
