Should I change 'Point' and 'Digits' to my Broker parameters
Odyssee
Post by Odyssee »
My broker, Tickmill, has 2 Digits and 0,01 Point as parameter for Gold (XAUUSD). Should I change it on Tickstory using the FXT Editor or these parameters depends on the data downloaded only and are not broker dependant?
I've attached 2 screenshots:
1. The default parameters from Tickstory for XAUUSD
2. The changed parameters for Tickmill
Thanks,
Tickmill parameters for XAUUSD
Default parameters for XAUUSD from Tickstory
Re: Should I change 'Point' and 'Digits' to my Broker parame
Hi Odyssee,
We recommend that you copy all your broker details the method described:
https://tickstory.com/forum/viewtopic.php?f=2&t=809
