What is the URL of Date Source with Dukascopy
slosh
Post by slosh »
I am in china,so the problem is the download data has been shielding by the china Firewall.
So can you tell me what is the URl for download data from Dukascopy webservice?
I want to use the URl for testing with web proxy...
The isses have been bothering me for a long time...
Pleas give me helps,thanks a lot!!!
Re: What is the URL of Date Source with Dukascopy
Hi Slosh,
Put this web address in your browser and if it downloads a file then you know you have solved the issue:
http://datafeed.dukascopy.com/datafeed/ ... _ticks.bi5
At the moment, we know of users who are using their own proxies or VPNs and this bypasses the restriction.
If you have any other solution that may assist others, please let us know!
