MT4 Launch Issue (Build 500)
ErodeMani
Post by ErodeMani »
I am new to Tickstory. You guys are really doing great job. I appreciate it.
I installed Tickstory version 0.8.1.0 and it is working fine until I started to face this MT4 Launch Issue problem.
I have been keep on getting this error stating "A suitable launcher could not be found for your metatrader version.
Launchers tride:
-Brit's Tick Data Suite
-Tickstory Launcher for Build........
Tickstory Launcher for build.........
I am using MT4 Version 4 Build 500.
Can you please help/guide in solving this issue......I have also posted the error scrheenshot
Re: MT4 Launch Issue (Build 500)
Hi ErodeMani,
Unfortunately the launcher does not currently support this version at the moment. You will need to use an earlier version of MT4 (Build 432-482) until the launcher is upgraded.
ErodeMani
Post by ErodeMani »
Thank you for the swift reply.
I could not find any MT4 Version of 432-482, even if I did, it automatically updates to current version.
Could you please guide me any other way to solve this MT4 Launcher problem
PipDigga
Post by PipDigga »
Hi Tickstory,
great software -- thank you.
1) "....until the launcher is upgraded." -- When will it be upgraded?
2) "...You will need to use an earlier version of MT4 (Build 432-482)..." I tried Build 482 (is the oldest I have) -- but it has built in "LiveUpdate".
I found no way to disable it. Can you Guys give me a link to download MT4 full version <build 482?
Hi there,
Please refer to the following post if you wish to downgrade your MT4 terminal:
http://www.tickstory.com/forum/viewtopic.php?f=4&t=173
As per our recommendation, you should install a MT4 version specifically for back-testing which will avoid automated upgrades and therefore wont cause interruptions to your testing.
We unfortunately don't have an ETA of when the launcher will be updated at this moment.
Hi all,
Support for Build 500 is currently in testing and will be available soon.
Hi all - v0.9.1 has just been released and provides support for MT4 Build 500+. You can read this post for further details:
http://www.tickstory.com/forum/viewtopic.php?f=5&t=192
Hope this helps!
johntiror
Post by johntiror »
I updated tickstory but I still can't launch my mt4 500 build. Why? I have the same error as above
Thanks!!
Hi John - please read this topic carefully to see if it resolves your issue:
http://www.tickstory.com/forum/viewtopic.php?f=4&t=204
