TickStory DataFormat Documentation
akifusenet
Post by akifusenet »
First of all thanks for this great application.
While trying out some export data format settings.
I found out that I could use some extra settings on the fields with by providing a ":"
For example.
:F2 floating point precision 2 digits
:C adds dollar sign
:P gives percentage
But I couldn't find a page with info about these settings.
Can you direct me to documentation with these settings?
This is what I need:
When I put :p to the field I want to export
0.55 turns into 55.00%
but
what I want is just the integer value 55
0.55 -> 55
It is basically like we are multiplying by 100 and round it to the next integer.
Is this possible?
Akif,
Re: TickStory DataFormat Documentation
Hi Akif,
The format specifiers conform to Microsoft .NET specifications which are detailed here:
https://docs.microsoft.com/en-us/dotnet ... at-strings
Our manual also details some of the format specifiers for dates here:
https://tickstory.com/help/tickstorylit ... le_exports
akifusenet
Thank you very much.
Akif,
