I've been reading this forum regarding FXT files saying that it cannot be greater than 4gb, but I have been running files that are 9-10gb. Is that normal or am I doing something wrong?
FXT File size limitation
Re: FXT File size limitation
Hi Drinkyd,
If you are a registered user, then the answer is that there should be no issue (if you are using the Lite version, then you should note there is a 365 day limitation which should not exceed 4gb). In some cases - perhaps due to greater machine resources and/or less EA requirements - the 4GB limit may not affect all users.
