1. If I select adjust timezone to "None", is the gmt/utc timezone (+0)?
2. If I want to mass change the timezone of the downloaded mt4 tick data do I have redownload all of them again or is there a shortcut?
MT4 Timezone help
MT4 Timezone help
- Capture.PNG (2.79 KiB) Viewed 8014 times
Re: mt4 timezone help
Hi Victor,
1) If adjust timezone is "None", then no modification is made to the native time format. For FX pairs, this is GMT. For other instruments such as DAX, it will be the local time of the exchange.
2) A time-shift requires all data to be rebuilt so you will need to export again.
Re: MT4 Timezone help
1. So it will be set accordingly dukascopy mt4 gmt timezone ? According to the dukascopy website "https://www.dukascopy.com/europe/englis ... -accounts/" is that gmt timezone used?
