Backtest MT4
Historical data from European markets.
Kowloonbar
Backtest MT4
Post by Kowloonbar »
When I import the tick in and do a backtest, with MT4. Then it doesn't show me 99%, but always only 30%, with modeling quality. what is the reason for this?
Re: Backtest MT4
Hello Kowloonbar,
Please check out our FAQ here which addresses all the possible reasons for not getting 99% modelling quality on your report.
If you continue to have issues, please post some screenshots of the issue (including your symbol name you are testing with) and we can assist further.
Kowloonbar
Re: Backtest MT4
I put it in the right folder and i didn't get an error message. I ran it for two days and took a screenshot. Maybe you can see the error.
Re: Backtest MT4
Hi Kowloonbar,
If you're getting 25% modelling quality, the reason is that the data is not in the correct location (eg. incorrect server selected) or the mapped symbol name is incorrect. It doesn't appear to be the latter, so please check that you have selected the data folder and server name in the Tickstory configuration.
If you are still having issues, could you please send us screenshots of the following:
1) The Tickstory "Export to MT4" settings you are using (including the "MT4 Settings" tab)
2) The MT4 Strategy Tester window (which shows the symbol name) (We already have this, thanks)
3) Your "MT4 Data Folder" FXT contents (go to File->Open data folder in Metatrader and then browse to tester/history and take a screenshot).
4) The 'Report' tab in Strategy Tester after your test is completed. (We already have this, thanks)
5) The Strategy Tester "Journal" tab after you have completed a back-test.
Kowloonbar
Re: Backtest MT4
I have now done everything as you wrote. Now I have modelling quality n/a. Is that ok, or should it say 99%?
Re: Backtest MT4
Hi Kowloonbar,
Did you press the "Launch" button in Tickstory? This is an important step as noted in the FAQ and this introductory video.
Kowloonbar
Re: Backtest MT4
when I load MT4 via Tickstory, I get this error message
Re: Backtest MT4
Please click on the download link you received via email after your puchase. This will give you the latest version which supports the most recent versions of MT4.
