Data accuracy is only 95% (Metatrader 5)
Quochuy112
Post by Quochuy112 »
I have followed the instructions of tickstory but when backtest EA on mt5 the data is only 95%. Guide me to fix this situation
Re: Data accuracy is only 95% (Metatrader 5)
Hi Quochuy112,
On Metatrader 5 (as opposed to MT4), they may be using some extra criteria to determine the modelling percentage. As long as you have followed the tick-data import guide here, then you should be using tick data. You can double-check by looking at the tick data loaded for that symbol in MT5's History Center.
Quochuy112
I want to backtest the M30 frame, do I need to load my MT5 any lower timeframes?
Hi Quochuy112,
I believe once you load the 1-minute data all the other time-frames are automatically calculated.
