question about N/A
alkosovi13
question about N/A
Post by alkosovi13 »
i use mt4 with tickstory light free
but I have resultmodelling quality N/A
first what means N/A??
and also ..is it good modelling quality for back test??
Re: question about N/A
Hi Alkosovi13,
You should always make sure that you are getting 99.9% modelling quality otherwise you cannot be sure that you are using Tickstory and, in the case of our Advanced Tester module, it will mean variable spreads, etc wont be working correctly.
Please see our FAQ here for more information.
