how to remove history data from history center
tickwaiting
Post by tickwaiting »
Hi Tickstory
how to delete downloaded data on history center, although it is deleted from tickstory data and from mt4 history and tester. but it's still there on history center, :mrgreen: the only way i found is to uninstall mt4 then reinstall. is there easier way to do it? :D
many thanks
Re: how to remove history data from history center
Hi Tickwaiting,
If you have removed the .HST files, it should only require a restart of the MT4 terminal to refresh its data. Of course, you will not have any charts displayed if there is no data and if you have your terminal connected to your broker, MT4 should automatically back-fill the data.
tickwaiting
Nice so I close charts and how to disconnect mt4 with broker while deleting the data?
Hi Tickwaiting, if you want to disconnect from your broker, you can go to File->Login to Account and type in an incorrect password and press ENTER.
This will log you out.
tickwaiting
great thanks tickstory i will give this a try and let you know how it will go
have a happy weekend
Thanks - have a great weekend yourself, Tickwaiting!
tickwaiting
tickstory wrote: Sat Nov 04, 2023 10:29 am Hi Tickwaiting, if you want to disconnect from your broker, you can go to File->Login to Account and type in an incorrect password and press ENTER.
Hi Tickstory, this tip worked very well many thanks 8-) now i can download and delete any data without uninstall metatrader platform :D
