Ask/Bid template tag exporting Bid/Ask values
pipnotic
Post by pipnotic »
Hi, there!
First of all thanks for a great piece of software! ;-)
I downloaded some tick data and exported it to CSV format using the custom template.
While doing that I noticed that the template tags for Ask and Bid ({AskPrice} and {BidPrice}) are mixed-up, with {AskPrice} exporting Bid values and {BidPrice} exporting Ask values.
That can even be verified when checking the Example output: with Data format set to
{Timestamp:yyyy.MM.dd} {Timestamp:HH:mm:ss:fff},{AskPrice},{BidPrice},1,1
the Example output is displayed as
2012.01.12 01:02:10:100,1.24231,1.24273,1,1
2012.02.13 02:04:10:332,1.24431,1.24473,1,1
Otherwise, rock-solid application!!
Cheers,
Pipnotic
Re: Ask/Bid template tag exporting Bid/Ask values
Hi Pipnotic - thanks for your keen eye and taking the time to log the issue.
We've looked at the issue and see that this affects only the sample record shown in the Export screen. That is, the Ask & Bid price in the sample record is 1.24431 and 1.24433, respectively. We will correct this in the next version. Meanwhile, the Ask & Bid prices that are actually exported to file should all be correct and as you expect.
Kind regards.
