Is my installation correct?
mmcfarlin
Post by mmcfarlin »
I just purchased and activated a Pro license after installing 1.9.7.15 Pro. But I initially had TickStory Lite installed. The screenshot shows that the data directory still has a lite config. Will this cause a problem. Downloads are still slow after activating the pro license.
mmcfarlin
Re: Is my installation correct?
Post by mmcfarlin »
Speed issue is resolved. download completed quickly. But the estimated time displayed shows performance of lite version.
I'm still wondering if the Lite config will cause a problem with other features.
Hi Mmcfarlin,
Welcome aboard! The configuration file is correct and should present no issue. The same configuration file is used for both the Lite and Professional version to ensure settings are preserved after an upgrade.
