Launch Issue Build 670 (solved / solution)
agora
Post by agora »
i have windows 7 64 Bit
Metatrader build 670
Remote Server
tickstory 1.5.10
I get the same error message like this http://www.tickstory.com/forum/viewtopic.php?f=4&t=204
i tried different Borker's MT4 setups, (AAAFX,ActiveTrades,Ajax).
The strange thing is i did exact the same installation and download like in my first desktop computer and all worked fine.
Now i have the launcher cant find problem, regardless what broker i select. Even AAAFX doesnt work (which should).
Only Difference is my commodo firewall, but i already allowed Tcikstory and MT4 as trusted permanent.
I dont have facebook, and my star is grey, just for info.
(in my first pc it worked without facebook, and grey star)
Info, when i try to click on the star nothing happens.
any ideas what could cause this bug, what could i exlude as error source?
or workaround?
thanks for your help.
Re: Launch Issue Build 670
Hi Agora,
If you are having issues clicking on the star, don't fret too much - the latest version of the application works the same with or without having a gold star.
agora
Post by agora »
OK,
but could you think of another error source which causes the launcher to fail permanently ?
(i mean i tried different broker , which work on another pc)
greetings
Hi Agora,
Could you please detail what error message you are getting? The launcher should not be tied down to a particular broker. The only thing that is relevant is the MT4 Build.
agora
Post by agora »
I installed the same setup (Tickstory 1.5.1 + AAAFX Mt4 build 670)
on a new XP SP3 installation and was facing the same launcher Problems.
After brute force try and error of 1 hour XD
i found the soloution.
I was trapped in a thought circle.
I always linked to the user datafolder (C:\users....\Terminal\Metaquotes\ and so on)
in the field where Tickstory requested MT4 Installation path and Mt4 Data path.
I thought it was correct because i work as user with limited rights (for security reasons).
So the soloution is :
under the field where Tickstory asks for Mt4 Installation the user must linkt to the mt4 installtion path
under Windows 7 it looks like this:
C:\Program Files (x86)\MetaTrader - AAAFx
and the mt4 Datafolder must link to the folder of the actual users mt4 folder looks like this (windows 7 64 bit german)
C:\Users\Internet\AppData\Roaming\MetaQuotes\Terminal\3BD2B5E5A5264AFE17C1E2DDC7D6B381
i attached a screenshot for better understanding
DMFX
Re: Launch Issue Build 670 (solved / solution)
Post by DMFX »
I am having the same problem that you did but when I try your solution I get a message stating that the MT4 directory is not valid. I have been trying to find a solution for ages, but I just can't get it to work! Does anyone have any idea what I am doing wrong?
This is just before I press the OK button
http://screencast.com/t/k36kT5vpebA
and then the message I get after pressing OK:
http://screencast.com/t/f9Npiin0
Any help would be appreciated.
Hi DMFX,
Please refer to the following post to see how Tickstory determines whether the folder you selected is a 'valid' MT4 location:
http://tickstory.com/forum/viewtopic.ph ... 237&p=1252
