Export in 4H, 30M time frames
jfroth82
Post by jfroth82 »
Is there a way to export data in the 4 hour (4H) and 30 min (30M) time frames? I noticed that the time frame jumps from 15M to hourly with nothing in between and from hourly to daily with nothing in between.
It would be most helpful to select a custom time frame to export data to (e.g. 20M, 30M, 2H, 4H, etc.)
admin
Site Admin
Re: Export in 4H, 30M time frames
Post by admin »
Hi jfroth,
File exports for custom time-frames is a good idea and has been put on the todo list. If you have some specific time-frames in mind that you would like (you've mentioned 30 min and 4 hourly - anything else?) then please let us know and we'll try get it in the next version.
jfroth82
Post by jfroth82 »
Great, thank you. 30M and 4H is what I need, but like I mentioned, it would be most helpful to have it totally customizable to any time frame you want.
admin
Site Admin
Post by admin »
Hi jfroth,
Support for exporting 30-minute, 4-hour and 12-hour time-frames to file will be available in the next release. Custom time-frames are on the todo list.
Hi jfroth,
This has been implemented in v0.8:
•[TICKLITE-62] File export: Added 30 minute, 4-hour and 12-hour export time-frames.
