mt5 import data issue
tickwaiting
Re: mt5 import data issue
Post by tickwaiting »
ok tickstory i will update you if i find solution at mql5 forum
Just a reminder that if you do raise the issue, just say "I have tried to import the following file format and get this result". If you mention third-party software, they sometimes get misdirected in their responses.
Hope that helps.
