Questions about pip
Questions about pip
Post by 3302424 »
If MetaTrader, set spreads and commissions
(Pictured)
Do I need to check the spread + embed additional data in the export
屏幕快照 2016-05-03 下午12.32.25.png (13.78 KiB) Viewed 17333 times
3302424
Re: Questions about pip
Post by 3302424 »
On MT4
Backtesting, need for re-set point difference?
viewtopic.php?f=2&t=766&p=4380#p4380 Here I do not understand
3302424
Post by 3302424 »
How to Set Up
Commission ECN accounts
For example: my commission money per hand 4
3302424
Post by 3302424 »
Spread on the question, understand, I can operate.
Spread need to manually set on MT4.
Now I do not understand
Whether the fee will be automatically taken into account?
It sounds like your commission settings need to be as follows:
Comm type: 0 (Money)
Base Comm: 4
Comm lots: 1 (Per trade)
Please check out this post for more information about commission settings:
viewtopic.php?f=2&t=346&p=1931
For the spread, please check out our release notes which have been updated to include a screenshot to hopefully clarify things for you:
https://tickstory.com/articles/tickstor ... -released/
Post by 3302424 »
Spread need to manually set up in MT4
TICKSTORY commission is set up to automatically calculate?
I use the Server mt4configo, automatically generate the correct data?
My English is not good, sorry.
That's correct - MT4 will automatically calculate the commission during the back-test.
Yes, you will need generate the settings for your broker via the TickstoryInfoExpert EA (instructions are in the "Help" tab in the 'Export to MT4' dialog window).
