insufficient data
Bob
insufficient data
Post by Bob »
we are unable to get data with for the periods as per description here:
https://tickstory.com/dukascopy-histori ... te-ranges/
for example we are unable to get data in Gold before 2013. The Error is 404 File not found.
another problem we have is the NASDAQ csv file. it just contains data until 2014.05.09.
We use version 1.7.4
Thanks for support
Re: insufficient data
Hi Bob,
It appears Dukascopy may have updated their databases for Gold (XAUUSD) and the data now starts on 4th May 2003. The website has been updated to reflect this.
Regarding NASDAQ, the database does start from 2011 although the data is patchy, perhaps reflecting the actual trading that was done on Dukascopy at the time. There is some data during April 2012, for example. The data is provided as-is.
Bob
Post by Bob »
Hello, thanks for reply.
after checking we were able to get the data for gold (XAUUSD). We originally used gold (AUCMDUSD). So thats solved.
Regarding NASDAQ:
You said: " There is some data during April 2012, for example."
Yes thats right. But there is no data after 2014.05.09.
The NASDAQ csv file:
Timestamp,Bid Price,Ask Price,Bid Volume,Ask Volume
2011.09.18 21:53:39.858,2622.31,2622.31,1,1
2011.09.19 13:30:20.254,2584.35,2584.35,1,1
2011.09.19 13:30:21.869,2583.6,2583.6,1,1
2011.09.19 13:30:26.232,2582.83,2582.83,1,1
2011.09.19 13:30:29.466,2582.45,2582.45,1,1
2011.09.19 13:30:31.934,2582.54,2582.54,1,1
2011.09.19 13:30:35.346,2582.13,2582.13,1,1
2014.05.09 19:59:40.085,4071.747,4071.785,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:43.089,4071.679,4071.713,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:46.594,4071.853,4071.888,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:47.295,4071.504,4071.551,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:49.198,4071.488,4071.527,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:52.103,4071.249,4071.294,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:56.109,4071.105,4071.148,0.0199999995529652,0.0199999995529652
2014.05.09 19:59:59.815,4071.26,4071.294,0.0199999995529652,0.0199999995529652
2014.05.09 20:00:02.824,4071.286,4071.332,0.0199999995529652,0.0199999995529652
there is no data after that. No data for 2015, no data for 2016.
We need data for this period like in your description.
Regards Bob
Hi Bob,
We have tried downloading the last week for USATECHIDXUSD and there is data available. I suggest you go to your "Dukascopy Store Folder" and delete all the years with missing data under the "USATECHIDXUSD" folder structure and then re-download it again. It may be the case that you attempted to download the data at a time where Dukascopy were performing database maintenance, resulting in no data.
I do hope this resolves your issue, but just a reminder that (as per our user-agreement) we provide data as-is with all its faults. As part of this, Dukascopy also stipulates numerous important conditions for the use of their data which you can find by browsing their website. We obviously try to provide the most up-to-date information, but this can change without notice.
Bob
Post by Bob »
I think our fault was to use USACOMIDXUSD instead of USATECHIDXUSD. We have data now.
Thank you for your support!
Regards Bob
Great to hear - thanks for letting us know!
