Hello, i am using the Birt suit and now i downloaded the 1.8.2 Tickstory.
But my terminal linked to these program, does't upgrades to latest version and now i am stuck with 950
Please advice.
MT4 build not upgrades
Re: MT4 build not upgrades
Hello SeriyGena,
Your terminal should automatically update if your broker has a later version available. Just make sure that you have not got the "/skipupdate" command-line switch in Tickstory's File->Settings->MT4 Settings.
If you are continuing to have issues, I suggest you download a new terminal from any broker. Once you have installed that terminal (and it has a later Build than 950), the next time you start your current MT4 terminal you should also get the updated version.
Thank you .
Issue resolved by itself. Terminal got upgrade
