Tick value
Sunnybeach
Tick value
Post by Sunnybeach »
For example, EURCAD. The tick vale is 0.77169 today by MarketInfo(Symbol(),MODE_TICKVALUE).
The backtest will start in deposit of USD while MT4 is online which has current USDCAD price.
Shall I input 0.77169 or 1 to export to MT4?
IMO, I should input 1 because MT4 will convert the profit to USD by current USDCAD price while backtesting.
Re: Tick value
Hi Sunnybeach,
In all cases, you should be acquiring these settings from your broker as described in this post:
viewtopic.php?f=2&t=809
Unless you specifically know the effect of the setting, it is not recommended to manually edit them. The parameters are internal to MT4.
