tickstory wrote:Hi RL2013,
Windows does not allow you to write data in the specified location (i.e. in your 'Program Files' directory). In your export file specification, specify a filename with a directory path such as "C:\XAGUSD.txt" (or in your 'Documents' folder) and this should work.
I can't export file. I got this message: Export failed: Access to the path 'C:\Program Files (x86)\Tickstory Lite\CL.csv' is denied. I turned Windows firewall off and still didn't work.
