while export to file.. data inspector is true.. But excel {BarBeginTime:yyyyMMdd},{BarBeginTime:HHmmss},0.99871,{High},0.99856,0.99862,286.529998898506
No date- Time and no High
Why.?
Output date format
Re: Output date format
Hi Utek,
Could you please tell us the following so we can try reproduce the issue:
- What is your Windows version.
- What are your regional settings.
- Any other information about your configuration that you may think is relevant.
Thank you.
Thank you.
Thanks for the information, Utek. Would you be able to tell us if it fixes the problem if you change to an English-based regional setting (such as U.S)?
I changeed to regional setting.. and everything is true...
But ı cant use my pc wıth english based regional setting..
what should I do?
Thank you for your sincere interest..
what should I do?
Hi Utek,
Does this mean you are no longer getting the issue in the Turkish language? If not, could you please let us know what you did to solve the issue?
