I think I have followed all the instructions, however it is not working for me. I have installed TS lite and downloaded all the data files, then exported to build 1045. It was not backtesting correctly so I read in the forums you have to downgrade to 765. So I installed a new version on another machine that is running 756 and call MT4 via the link in TS lite, however that machine will not run the basic Expert Advisors that come with the install such as MACD Sample and Moving Average.
So I then just tried to export the data to a csv file from TS lite and I get this "Export Failed. Access to path denied". Is there any way to have TS lite function as intended?
Thank you.
Does Tickstory Lite Work?
Re: Does Tickstory Lite Work?
Hi Skm,
If you have rolled back your Metatrader version to 765 or below, ensure also that you have rolled back Metaeditor.exe, especially if you have Build 1045 versions of the standard EAs (MACD Sample, etc). You then should be able to recompile these EAs so they work on the older build. Of course, we can only provide limited support for the free version but we do welcome further discussion within our forums with other 'lite' users. We will pitch-in whenever we get a moment.
As for the 'access denied' error, please check out or FAQ or be sure to search the forum for answers:
https://tickstory.com/forum/viewtopic.php?f=2&t=613
https://tickstory.com/forum/search.php? ... ess+denied
