Hi all, I've reversed MT4 to version 765 to be able to launch it via Tickstory Lite. However, when launched, I can't see the symbol of the previously downloaded historical data in the tester window and, of course, being offline I can't see any other symbol.
The upper side of the MT4 window says "Metatrader 4 with Tickstory Launcher(FXT Overwrite Prevention Fixed Spread", and the historical data downloaded with Tickstory are cointained in FXT format in
C:\Program Files (x86)\FXCM MetaTrader 4\tester\history
C:\Program Files (x86)\FXCM MetaTrader 4\history\FXCM-EURDemo01
Any help?
Thanks in advance
Can't see historical data in MT4
Re: Can't see historical data in MT4
Hi Leo,
Would you have a screenshot of what you are seeing? The MT4 terminal needs to display the symbol you are exporting, otherwise you will not be able to utilise the exported data.
