0.8 - readonly and fxt overwrite
p4spares
Post by p4spares »
hi,
i updated to 0.8 version, and im having some problems.
first problem, is about the 'make fxt readonly' checkbox. after export fxt files are writeable.
i make it readonly from windows explorer (im using win7) and i run MT4 build 432 (the same was working with the previous version).
the i run my backtest, seems MT4 is not patched and fxt files are overwritten.
now i reinstalled the 0.7.
any idea?
thanks,
David
grafikk
Re: 0.8 - readonly and fxt overwrite
Post by grafikk »
i have the same problem
Hi p4spares,
The 'read-only' FXT file option has been tested on Windows 7 and the files are being correctly flagged. Will need some further information about what you are checking to get your result
With regard to the launcher, there seems to be an issue with some Windows 7 users having problems. Further investigation will be required. If v0.7 works fine for you, you may need to revert back. Note there have been no changes to the launcher between 0.7 and 0.8, so the issue seems specific to Windows 7.
Will let you know when there is further information on this.
Regards
Hi all,
Just an update on this issue - we believe we have found the problem and will be releasing a interim version for users to see whether it resolves the issue under their platform.
Stay tuned.
Hi all,
The software has just been updated to v0.8.1 to address the found issue. Please see the updated v0.8 announcement here:
http://www.tickstory.com/forum/viewtopi ... 0455a#p407
tcferreira
Post by tcferreira »
Ok I'll be taking the test. I'm with Windows 8 Pro
Until more!
