Backtesting consumes ALL my disk space
dylanshilts
Post by dylanshilts »
Not sure why but when I backtest my EA the report will only read up to 6236 bars, I have it backtesting for 8 months on the 1 hr chart. I change the settings to backtest only one month and same thing, it only reads up to 6236 bars then stops the back test. This has nothing to do with my computer as I literally just bought this new computer only for this reason, to backtest with the tickstory data.
This would be much easier to resolve over skype or team viewer if that is possible. Please assist
Re: Backtesting consumes ALL my disk space
Hi Dylanshilts,
If your back-test is stopping prematurely, please ensure that your data (FXT) files are less than 4GB as described in our FAQ:
https://tickstory.com/help/tickstorylit ... kteststops
If you are still having problems with the back-test stopping prematurely, make sure there no errors are being reported by your EA (check the 'Journal' tab in the Strategy Tester).
If you are having problems with disk space, it is recommended that you export only the time-frames you typically test in. For example, if you typically have strategies that use the 5-minute time-frame, only check the "5M" on the "Export FXT Timeframes" check-box in the MT4 Export window.
paulson617
Post by paulson617 »
I would like to export M1 Time Frame only, but it doesn't matter how many times uncheck M5, M15, M30 ... and W1, the program continues to export all the frames.
It seems to me that deactivating the boxes doesn't work. How to export only the time frame I want, and not all at the same time?
Hi Paulson617,
Unfortunately it looks like your images haven't come through. In any case, please note that the .HST files of all time-frames will always be exported. This is a requirement for MT4 to back-test correctly (and the charts of all time-frames to be visible). It is the .FXT files which are the testing tick data files which are the large files and only the ones you check will be produced.
