GMT shift (+1/+2)
moneyball77
GMT shift (+1/+2)
Post by moneyball77 »
I have a question about how to correctly set the GMT in the panel.
Should I use the GMT of my local zone (which is UTC +1) or my broker's (UTC +2)?
I believe it's the latter, but you tell me.
Re: GMT shift (+1/+2)
Hi Moneyball,
You might need to be a bit more specific about what you are trying to do, but if you are trying to simply ensure the exported data is the same as your broker's then set UTC+2. More specifically, you might want to check with your broker if the "UTC +2 with European/London DST" option is more appropriate if your broker automatically accounts for daylight savings.
For more information, you can see our manual on this topic:
https://tickstory.com/help/tickstorylit ... time-zones
This thread may also help:
https://tickstory.com/forum/viewtopic.php?f=2&t=1594
