multi mt4
hir0406
multi mt4
Post by hir0406 »
hello,
can we run more than 1 mt4 at same time for testing via tickstory?
quality of data should be 99% or 99.99%?
Re: multi mt4
Hi Hir0406,
If you want to run more than 1 MT4, you will need to manually reconfigure to the other MT4 installation and launch it. You should be getting 99.9% modelling quality.
hir0406
Re: multi mt4
Post by hir0406 »
Can I use same license 2 different machines?
Re: multi mt4
Hi, yes you have two activations available per license.
