My XAUUSD can not execute the percent stop loss
but I can execute on MT4 history data.
only tickstory cant
I suspect that I exported the problem
Can you provide a template?
XAU set
Re: XAU set
Hi MaxShih,
It is important to know why your stop-loss is not being set. Tickstory only exports pricing data and after that, the MT4 Strategy Tester and your EA is responsible for setting the stop-loss. If your stop loss is not getting entered, it can only mean that:
1) Your EA is not creating a stop-loss.
2) MT4 Strategy Tester is rejecting your stop-loss command.
In the case of 2), the EA Journal should tell you this.
Before you proceed, please make sure you have acquired all your broker's correct settings for XAU by following this method: https://tickstory.com/forum/viewtopic.php?f=2&t=809
Hope this helps!
Hope this helps!
