Reactivation after reinstalling windows
Hello. I want to reinstall windows on my local PC. How can i get my program still working, without buying the new version?
Re: Reactivation after reinstalling windows
Hi Rabbi,
If you can, uninstall the program first and re-install when you have re-installed Windows.
FYI, we cannot find your license with the email you have provided, so if you need further assistance appreciate if you can provide us with this information.
Yes i can do it the way you described. I will uninstall it first.
The program was registered on this emaIL ***@**.com. My sign up e-mail is the second license.
Hi Rabbi, Thanks for the details - we've updated your email address on the forum so we can assist you better. FYI we have no record of your other email.
can you check this one (vdolman at gmail dot com)
Yep - got it, thanks. Would you like to consolidate your email addresses into one or is this for a different user? If the latter, then the other user can set up their own user account on the forum if they like.
My windows HDD crashed and would like to reinstall tickstory...my original download link has long expired please help..
Hi Jtcnote, you download link has been resent to you. Thanks!
