mt4 build 489
xspace
mt4 build 489
Post by xspace »
Hello
First of all, thank you for tickstory sw. it is very helpfull piece of sw. ;) The TS worked fine until yesterday. I got message after F8: suitable loader could not be found for yout MT version. It looks like MT4 has updated to build 489 /release date 18.4.2013/ so the question is.... would be there an udate of TS loader with support for this MT4 build version? or when can I found the older build of MT4? /i searched but not found/ ?
regards ,
Markus
Re: mt4 build 489
Hi Markus,
Welcome to the forum and thanks for your post. We will look into adding support for the latest build. Until then, you can download Build 432 from here:
http://www.multiupload.nl/2AB9S9505T
Kind regards.
boji
Re: mt4 build 489
Post by boji »
Hi, i cant access http://www.multiupload.nl/PL_2AB9S9505T for download, could u help me?
Re: mt4 build 489
Hi Boji - I'm not sure what error you are getting but you can try one of the links listed on that page:
(link removed due to expiry)
drcrck
Re: mt4 build 489
Post by drcrck »
whatch out! pulocker is a scam software!
Re: mt4 build 489
Hi drcrk,
Thanks for the heads up. It seems the link has expired. We will get a new link for the software shortly.
Regards
Tradexfol
Re: mt4 build 489
Post by Tradexfol »
Good morning.
Can anyone share MT4 compatible?
Thank you very much!
Re: mt4 build 489
Hi all,
A version of MT4 Build 432 can be found here:
http://www.tickstory.com/files/MetaTrader432.7z
Tradexfol
Re: mt4 build 489
Post by Tradexfol »
tickstory wrote:Hi all,
Thank you very much Tickstory.
I have a problem. MT4 does not connect, says:
"previous version".
I can not activate MT4, and knows no tickstory to mt4.
Re: mt4 build 489
Hi Tradexfol,
Can you please confirm you are using the MT4 Build 432 as provided in the link above? The terminal will not connect to a broker (as expected), however you should be able to perform a back-test correctly.
