Automatic starting dates per instrument
Haeggor
Post by Haeggor »
Hey there,
if the user selects a date that is earlier then the first available data for a given instrument, tickstory will request all data regardless, resulting in a lot of 404's and a long waiting time until the first download starts. This could be prevented.
in jforex there is a function where the first available datapoint timestamp for a given instrument, in any given timeframe can be requested:
https://www.dukascopy.com/client/javado ... nstrument)
Using this data, Tickstory could be programmed to start requesting at the first available data, instead of the starting date the user set(If the starting date the user set is earlier then the actual start of the data).
This would minimize the amount of 404s from the server, reduce server load and greatly improve tickstories time to start downloading.
Now tickstory could request the data every time from dukascopy, but this would require the use of java, the jforex api, and at least a demo account that is not time limited. But this may not be necessary.
I am assuming that no new data is being added to the history, and that only data going forward in time is added by dukascopy. If this is the case, then simply having a list of starting dates would be good enough for
tickstory to know when to actually start the download. If you want, I could read this data out from jforex and give it to you. (maybe even get a lifetime free tickstory license in the process? :D ).
Even if they would add more history prior to the current starting points, tickstory could include an option to disable those limits just in case.
I am assuming that tickstory ALWAYS downloads tick data. If necessary, I could provide the times of first candles for any timeframe, though.
let me know what you think.
Re: Automatic starting dates per instrument
Hi Haeggor,
Thanks for your suggestion. We're on to this one since we do have all the dates already coded in. Just need to do a little magic on the user-interface ;)
For the moment, I assume you're aware that we maintain a page with all the earliest dates available for each symbol here: https://tickstory.com/dukascopy-histori ... te-ranges/
P. S. Tickstory caches the data on your disk and doesn't re-download this information from the web unless it is missing/deleted.
Haeggor
Post by Haeggor »
Thanks for your reply. Cool, I did not know the page with the dates. Going through your list, I spotted two instruments that are selectable in tickstory but missing on your page: AUDCAD, USDCNH. And CHFSGD appears twice in your list. Stuff like this happens to my lists all the time. :lol:
I know that data does not get re-downloaded. However, when selecting a date that is prior to the start of the available server data, it will still try to download it(since it never was downloaded because it does not exist), resulting in a lot of 404's.
Me, being a lazy programmer, I would skip showing the correct first available date in the guis date selection (which is more complicated when doing a batch download of multiple instruments), and just ignore the user input date (if the date is earlier than the first available data) and start where the data begins, not where the user wants it to start. Maybe add an option to override this behavior in the options, just in case the start of the data changes. But that's just me. :D
Haeggor
Post by Haeggor »
I've downloaded the starting dates (timeframe TICK) today for all crossrates since at least one of the dates on your page seems not to be correct (i.e. AUDCAD starts on the page at 2010, while the first data online is available at 2006).
I removed all crossrates that are listed in the api but at the time of coding did not contain any data and/or were not tradeable on the dukascopy platform ( i.e. CHF/PLN, EUR/BRL etc). As far as I can tell you did the same on your page.
Below that list, you'll also find all non forex instruments but that list is not presorted. Data is as accurate as it can get, down to the milliseconds.
Have fun. :D
Here is the list of crossrates plus gold and silver, separated by semicolon for easy digestion:
Forex Instrument;Starting Date (yyy.MM.dd HH:mm:ss.SSS)
AUD/JPY;2003.11.30 23:00:00.662
AUD/CAD;2006.01.03 01:00:05.860
AUD/CHF;2006.03.01 01:01:00.898
AUD/NZD;2006.12.12 01:01:02.665
AUD/SGD;2007.03.14 01:00:20.923
AUD/USD;2003.08.03 23:00:05.044
CAD/CHF;2006.01.02 23:38:05.365
CAD/HKD;2007.03.13 06:44:28.143
CAD/JPY;2004.10.25 02:01:01.975
CHF/JPY;2003.08.03 23:00:14.329
CHF/SGD;2007.06.04 11:31:10.450
EUR/AUD;2005.10.07 07:54:01.827
EUR/CAD;2004.10.25 02:00:05.847
EUR/CHF;2003.08.03 23:00:00.609
EUR/DKK;2004.10.25 02:33:06.743
EUR/GBP;2003.08.03 23:00:00.158
EUR/HKD;2007.03.13 05:52:10.251
EUR/HUF;2007.03.14 03:00:36.414
EUR/JPY;2003.08.03 23:00:01.007
EUR/NOK;2004.10.25 02:18:08.311
EUR/NZD;2006.01.02 23:38:22.520
EUR/PLN;2007.03.14 01:00:03.095
EUR/RUB;2007.03.13 06:56:01.608
EUR/SEK;2004.10.27 19:16:02.597
EUR/SGD;2007.03.13 05:42:05.186
EUR/TRY;2007.03.13 05:54:03.245
EUR/USD;2003.05.04 23:00:00.914
GBP/AUD;2006.03.22 01:00:08.802
GBP/CAD;2006.01.02 23:38:05.784
GBP/CHF;2003.08.04 12:00:05.092
GBP/JPY;2003.08.03 23:00:00.015
GBP/NZD;2006.01.02 23:38:05.298
GBP/USD;2003.05.04 23:00:00.773
HKD/JPY;2007.03.13 05:30:00.096
NZD/CAD;2006.01.02 23:38:06.805
NZD/CHF;2006.01.02 23:38:04.259
NZD/JPY;2006.01.02 23:39:04.109
NZD/USD;2003.08.03 23:00:00.203
SGD/JPY;2007.03.13 05:01:00.144
USD/CAD;2003.08.03 23:00:01.482
USD/CHF;2003.05.04 23:00:01.179
USD/CNH;2012.06.27 02:07:42.688
USD/CZK;2016.01.03 23:00:12.197
USD/DKK;2003.08.04 02:00:09.907
USD/HKD;2007.03.13 05:01:10.075
USD/HUF;2007.03.13 05:58:03.671
USD/JPY;2003.05.04 23:00:00.626
USD/MXN;2007.03.13 08:01:04.762
USD/NOK;2003.08.04 02:00:08.997
USD/PLN;2007.03.13 05:56:04.776
USD/RON;2016.12.18 23:00:00.837
USD/RUB;2007.03.13 08:03:01.766
USD/SEK;2003.08.04 02:00:01.201
USD/SGD;2004.11.16 19:03:02.644
USD/TRY;2007.03.13 08:01:00.664
USD/ZAR;2003.08.04 12:03:02.837
XAG/USD;2003.05.05 01:09:04.025
XAU/USD;2003.05.05 02:01:03.421
ZAR/JPY;2007.06.04 02:00:18.146
TRY/JPY;2010.05.09 23:43:33.000
Also, here is the list of all non-forex instruments with their respective starting dates. Keep in mind however, that I did not sort those like I did with the forex pairs, meaning there could be instruments with no data and/or that are not tradeable on the dukascopy platform.
Non-Forex Instrument;Starting Date (yyy.MM.dd HH:mm:ss.SSS)
BRENT.CMD/USD;2010.12.02 02:00:33.111
LIGHT.CMD/USD;2013.01.01 06:44:02.453
DEU.IDX/EUR;2013.01.01 06:44:03.103
FRA.IDX/EUR;2013.01.01 06:44:03.107
CHE.IDX/CHF;2013.01.01 06:44:03.107
GBR.IDX/GBP;2013.01.01 04:51:37.835
JPN.IDX/JPY;2013.01.01 06:44:03.106
USA30.IDX/USD;2013.01.01 06:44:03.104
USATECH.IDX/USD;2013.01.01 06:44:03.105
USA500.IDX/USD;2012.01.16 01:00:07.771
AUS.IDX/AUD;2014.06.02 01:50:09.337
EUS.IDX/EUR;2014.06.02 08:00:57.299
NLD.IDX/EUR;292278994.08.17 08:12:55.807
ITA.IDX/EUR;292278994.08.17 08:12:55.807
ESP.IDX/EUR;2014.06.02 09:01:09.603
HKG.IDX/HKD;2013.06.03 03:15:21.916
PRT.IDX/EUR;292278994.08.17 08:12:55.807
COPPER.CMD/USD;2012.03.02 01:00:07.445
GAS.CMD/USD;2012.09.03 00:02:33.889
MMM.US/USD;2017.05.11 15:32:14.712
AXP.US/USD;2017.11.02 14:30:00.157
T.US/USD;2017.01.26 15:30:01.438
BA.US/USD;2017.01.26 15:30:02.524
CAT.US/USD;2017.05.11 15:30:05.283
CVX.US/USD;2017.01.26 15:30:01.325
CSCO.US/USD;2017.01.26 15:30:01.331
KO.US/USD;2017.01.26 15:30:01.437
DD.US/USD;292278994.08.17 08:12:55.807
XOM.US/USD;2017.01.26 15:30:02.039
GE.US/USD;2017.01.26 15:30:01.829
GS.US/USD;2017.01.26 15:30:01.327
HD.US/USD;2017.01.26 15:30:01.325
INTC.US/USD;2017.01.26 15:30:01.438
IBM.US/USD;2017.01.26 15:30:01.437
JNJ.US/USD;2017.01.26 15:30:01.137
JPM.US/USD;2017.01.26 15:30:01.636
MCD.US/USD;2017.11.02 14:30:00.334
MRK.US/USD;2017.11.02 14:30:01.242
MSFT.US/USD;2017.01.26 15:30:02.717
NKE.US/USD;2017.11.02 14:30:00.809
PFE.US/USD;2017.01.26 15:30:01.582
PG.US/USD;2017.01.26 15:30:01.599
TRV.US/USD;2017.11.02 14:30:00.418
UTX.US/USD;2017.11.15 16:23:27.747
UNH.US/USD;2017.11.02 17:21:11.460
VZ.US/USD;2017.11.15 16:49:15.137
V.US/USD;2017.01.26 15:30:02.038
WMT.US/USD;2017.11.15 17:41:08.568
DIS.US/USD;2017.01.26 15:30:02.437
TSLA.US/USD;2017.01.26 15:30:02.332
AMZN.US/USD;2017.01.26 15:30:01.221
FB.US/USD;2017.01.26 15:30:01.438
ADBE.US/USD;2017.05.11 15:30:10.165
AAPL.US/USD;2017.01.26 15:30:01.325
EBAY.US/USD;2017.11.02 14:30:00.049
ALXN.US/USD;2017.01.26 15:30:02.025
YHOO.US/USD;292278994.08.17 08:12:55.807
GOOG.US/USD;2017.01.26 15:30:01.581
SBUX.US/USD;2017.11.02 14:30:00.335
WIN.US/USD;292278994.08.17 08:12:55.807
AVGO.US/USD;2017.01.26 15:30:01.440
LBTYA.US/USD;292278994.08.17 08:12:55.807
DISH.US/USD;292278994.08.17 08:12:55.807
CERN.US/USD;2018.01.31 16:24:21.361
NXPI.US/USD;292278994.08.17 08:12:55.807
XLNX.US/USD;2018.02.01 16:40:19.061
VRSK.US/USD;292278994.08.17 08:12:55.807
ISRG.US/USD;2018.02.01 15:30:31.999
NDAQ.US/USD;292278994.08.17 08:12:55.807
CA.US/USD;292278994.08.17 08:12:55.807
PAYX.US/USD;2018.02.01 15:50:48.897
ZION.US/USD;292278994.08.17 08:12:55.807
SIRI.US/USD;292278994.08.17 08:12:55.807
AKAM.US/USD;292278994.08.17 08:12:55.807
FFIV.US/USD;292278994.08.17 08:12:55.807
PCLN.US/USD;2017.01.26 15:30:14.016
EXPD.US/USD;292278994.08.17 08:12:55.807
HAS.US/USD;292278994.08.17 08:12:55.807
NTRS.US/USD;292278994.08.17 08:12:55.807
PCAR.US/USD;2018.02.01 15:50:58.811
GOOGL.US/USD;2017.01.26 15:30:01.580
ETFC.US/USD;292278994.08.17 08:12:55.807
AAL.US/USD;2017.11.02 14:30:00.002
CTRX.US/USD;292278994.08.17 08:12:55.807
AMAT.US/USD;2017.05.11 15:30:03.833
ALTR.US/USD;292278994.08.17 08:12:55.807
LMCK.US/USD;292278994.08.17 08:12:55.807
QVCA.US/USD;292278994.08.17 08:12:55.807
HSIC.US/USD;292278994.08.17 08:12:55.807
ADI.US/USD;2018.01.30 17:05:35.585
ADSK.US/USD;2018.01.30 17:19:51.890
MDLZ.US/USD;2017.11.02 14:30:00.092
MYL.US/USD;292278994.08.17 08:12:55.807
TXN.US/USD;2017.11.02 14:30:00.095
TRIP.US/USD;292278994.08.17 08:12:55.807
GRMN.US/USD;292278994.08.17 08:12:55.807
CTXS.US/USD;2018.01.31 16:25:07.283
NVDA.US/USD;2017.01.26 15:30:01.603
CTAS.US/USD;292278994.08.17 08:12:55.807
WYNN.US/USD;2017.11.15 17:42:00.303
DISCA.US/USD;292278994.08.17 08:12:55.807
FAST.US/USD;292278994.08.17 08:12:55.807
MU.US/USD;2017.11.02 14:30:00.026
BRCM.US/USD;292278994.08.17 08:12:55.807
INTU.US/USD;2018.02.01 15:30:01.401
VIP.US/USD;292278994.08.17 08:12:55.807
NAVI.US/USD;292278994.08.17 08:12:55.807
QCOM.US/USD;2017.11.02 14:30:00.002
TROW.US/USD;2018.02.01 16:35:14.304
EQIX.US/USD;292278994.08.17 08:12:55.807
LVNTA.US/USD;292278994.08.17 08:12:55.807
CME.US/USD;2017.05.11 15:30:08.751
BBBY.US/USD;292278994.08.17 08:12:55.807
ATVI.US/USD;2017.05.11 15:30:07.909
FOSL.US/USD;292278994.08.17 08:12:55.807
MNST.US/USD;292278994.08.17 08:12:55.807
CHRW.US/USD;292278994.08.17 08:12:55.807
SPLS.US/USD;292278994.08.17 08:12:55.807
STX.US/USD;292278994.08.17 08:12:55.807
FISV.US/USD;292278994.08.17 08:12:55.807
KLAC.US/USD;292278994.08.17 08:12:55.807
PDCO.US/USD;292278994.08.17 08:12:55.807
ADP.US/USD;2017.11.02 14:30:00.569
TSCO.US/USD;292278994.08.17 08:12:55.807
NFLX.US/USD;2017.01.26 15:30:01.582
ILMN.US/USD;2018.02.01 15:30:03.855
BIDU.US/USD;2017.11.02 14:30:00.827
XRAY.US/USD;292278994.08.17 08:12:55.807
CHTR.US/USD;292278994.08.17 08:12:55.807
SBAC.US/USD;292278994.08.17 08:12:55.807
DTV.US/USD;292278994.08.17 08:12:55.807
FOX.US/USD;292278994.08.17 08:12:55.807
REGN.US/USD;2017.11.02 14:30:00.823
LBTYK.US/USD;292278994.08.17 08:12:55.807
SYMC.US/USD;2018.02.01 16:32:11.231
GT.US/USD;292278994.08.17 08:12:55.807
SNDK.US/USD;292278994.08.17 08:12:55.807
FOXA.US/USD;2018.01.31 16:28:22.575
CINF.US/USD;292278994.08.17 08:12:55.807
MAR.US/USD;2017.11.02 14:30:00.086
SRCL.US/USD;292278994.08.17 08:12:55.807
FITB.US/USD;2018.01.31 16:28:01.534
PBCT.US/USD;292278994.08.17 08:12:55.807
CHKP.US/USD;292278994.08.17 08:12:55.807
VOD.US/USD;292278994.08.17 08:12:55.807
EA.US/USD;2017.05.11 15:30:05.805
ORLY.US/USD;2017.11.02 14:30:00.517
VIAB.US/USD;2018.02.01 16:38:35.615
HBAN.US/USD;292278994.08.17 08:12:55.807
FLIR.US/USD;292278994.08.17 08:12:55.807
FTR.US/USD;292278994.08.17 08:12:55.807
CMCSA.US/USD;2017.01.26 15:30:01.604
ESRX.US/USD;2017.11.02 14:30:00.195
MCHP.US/USD;2018.02.01 15:30:09.599
BIIB.US/USD;2017.05.11 15:30:07.519
GMCR.US/USD;292278994.08.17 08:12:55.807
VRSN.US/USD;292278994.08.17 08:12:55.807
ROST.US/USD;2018.02.01 16:19:13.389
COST.US/USD;2017.11.02 14:30:00.352
HCBK.US/USD;292278994.08.17 08:12:55.807
DISCK.US/USD;292278994.08.17 08:12:55.807
EXPE.US/USD;2017.11.02 14:30:00.078
CTSH.US/USD;2017.11.02 14:30:00.003
CELG.US/USD;2017.05.11 15:30:06.410
AMGN.US/USD;2017.01.26 15:30:01.440
SIAL.US/USD;292278994.08.17 08:12:55.807
DLTR.US/USD;2017.11.02 14:30:00.003
CMCSK.US/USD;292278994.08.17 08:12:55.807
WDC.US/USD;292278994.08.17 08:12:55.807
FSLR.US/USD;292278994.08.17 08:12:55.807
LLTC.US/USD;292278994.08.17 08:12:55.807
WFM.US/USD;292278994.08.17 08:12:55.807
NWSA.US/USD;292278994.08.17 08:12:55.807
LMCA.US/USD;292278994.08.17 08:12:55.807
LRCX.US/USD;2017.11.02 14:30:00.810
MAT.US/USD;2018.02.01 15:30:10.108
URBN.US/USD;292278994.08.17 08:12:55.807
NTAP.US/USD;292278994.08.17 08:12:55.807
GILD.US/USD;2017.01.26 15:30:01.327
VRTX.US/USD;2017.11.15 16:48:41.349
PETM.US/USD;292278994.08.17 08:12:55.807
AEP.US/USD;2016.09.26 16:30:34.288
SPY.US/USD;2017.02.16 16:27:00.989
BABA.US/USD;2017.01.26 15:30:00.107
BAC.US/USD;2017.01.26 15:30:01.580
C.US/USD;2017.01.26 15:30:01.589
EEM.US/USD;2017.01.26 15:30:01.122
EFA.US/USD;2017.01.26 15:30:01.327
EWJ.US/USD;2017.01.26 15:30:01.203
GDX.US/USD;2017.01.26 15:30:01.219
GLD.US/USD;2017.01.26 15:30:01.329
IWM.US/USD;2017.01.26 15:30:00.116
IYR.US/USD;2017.01.26 15:30:01.437
JNK.US/USD;2017.01.26 15:30:00.117
QQQ.US/USD;2017.01.26 15:30:01.228
TLT.US/USD;2017.01.26 15:30:00.124
WFC.US/USD;2017.01.26 15:30:00.110
XLF.US/USD;2017.01.26 15:30:01.203
XLI.US/USD;2017.01.26 15:30:01.118
XLP.US/USD;2017.01.26 15:30:01.227
XIV.US/USD;292278994.08.17 08:12:55.807
VXX.US/USD;2017.01.26 15:30:01.220
BBD.US/USD;2017.01.26 15:30:02.345
ABEV.US/USD;2017.01.26 15:30:00.107
VALE.US/USD;2017.01.26 15:30:01.440
FXI.US/USD;2017.01.26 15:30:01.323
ITUB.US/USD;2017.01.26 15:30:01.318
PBR.US/USD;2017.01.26 15:30:01.224
EWZ.US/USD;2017.01.26 15:30:01.601
NOK.US/USD;292278994.08.17 08:12:55.807
AZN.US/USD;2017.01.26 15:30:01.437
CS.US/USD;2017.01.26 15:30:02.720
LVS.US/USD;2017.01.26 15:30:01.585
USO.US/USD;2017.01.26 15:30:17.170
XOP.US/USD;2017.01.26 15:30:01.318
GDXJ.US/USD;2017.01.26 15:30:01.437
A.US/USD;2017.05.25 16:30:00.057
ABT.US/USD;2017.05.11 15:30:39.284
AET.US/USD;2017.05.11 15:30:45.295
AIG.US/USD;2017.05.11 15:30:33.872
BBY.US/USD;2017.05.11 15:30:12.538
BK.US/USD;2017.05.11 15:30:05.374
BMY.US/USD;2017.05.11 15:31:06.514
BRKB.US/USD;2017.11.06 15:30:01.318
BSX.US/USD;2017.05.11 15:30:08.946
CI.US/USD;2017.05.11 15:30:06.241
CMG.US/USD;2017.05.11 15:30:05.614
CRM.US/USD;2017.05.11 15:30:14.053
DE.US/USD;2017.05.11 15:30:05.353
DG.US/USD;2017.05.11 15:30:05.807
DIA.US/USD;2017.05.11 15:30:01.725
DUK.US/USD;2017.05.11 15:30:08.946
DVY.US/USD;2017.05.11 15:30:13.852
EMB.US/USD;2017.05.11 15:30:07.469
EWH.US/USD;2017.11.06 15:30:01.544
EWW.US/USD;2017.03.13 15:25:17.008
GLW.US/USD;2017.05.11 15:30:47.470
IBB.US/USD;2017.05.11 15:30:05.981
ICE.US/USD;2017.11.06 15:30:02.181
IJR.US/USD;2017.05.11 15:30:04.642
ITW.US/USD;2017.05.11 15:30:05.551
IVE.US/USD;2017.05.11 15:30:05.806
IVW.US/USD;2017.05.11 15:30:06.635
JWN.US/USD;2017.05.11 15:30:53.414
K.US/USD;2017.05.11 15:30:15.645
KHC.US/USD;2017.05.11 15:30:09.831
KMB.US/USD;2017.05.11 15:30:05.391
L.US/USD;2017.05.11 15:30:05.315
LEN.US/USD;2017.05.11 15:30:15.190
LLY.US/USD;2017.05.11 15:31:11.536
LMT.US/USD;2017.05.11 15:30:06.360
MA.US/USD;2017.05.11 15:30:06.426
NOC.US/USD;2017.05.11 15:31:47.575
OXY.US/USD;2017.05.11 15:30:16.415
NEW.US/USD;292278994.08.17 08:12:55.807
1299.HK/HKD;292278994.08.17 08:12:55.807
3988.HK/HKD;292278994.08.17 08:12:55.807
3328.HK/HKD;292278994.08.17 08:12:55.807
0023.HK/HKD;292278994.08.17 08:12:55.807
1880.HK/HKD;292278994.08.17 08:12:55.807
2388.HK/HKD;292278994.08.17 08:12:55.807
0293.HK/HKD;292278994.08.17 08:12:55.807
0001.HK/HKD;292278994.08.17 08:12:55.807
0939.HK/HKD;292278994.08.17 08:12:55.807
2628.HK/HKD;292278994.08.17 08:12:55.807
2319.HK/HKD;292278994.08.17 08:12:55.807
0144.HK/HKD;292278994.08.17 08:12:55.807
0941.HK/HKD;292278994.08.17 08:12:55.807
0688.HK/HKD;292278994.08.17 08:12:55.807
0386.HK/HKD;292278994.08.17 08:12:55.807
0291.HK/HKD;292278994.08.17 08:12:55.807
1109.HK/HKD;292278994.08.17 08:12:55.807
0836.HK/HKD;292278994.08.17 08:12:55.807
1088.HK/HKD;292278994.08.17 08:12:55.807
0762.HK/HKD;292278994.08.17 08:12:55.807
0267.HK/HKD;292278994.08.17 08:12:55.807
0002.HK/HKD;292278994.08.17 08:12:55.807
0883.HK/HKD;292278994.08.17 08:12:55.807
0027.HK/HKD;292278994.08.17 08:12:55.807
0101.HK/HKD;292278994.08.17 08:12:55.807
0011.HK/HKD;292278994.08.17 08:12:55.807
0012.HK/HKD;292278994.08.17 08:12:55.807
1044.HK/HKD;292278994.08.17 08:12:55.807
0003.HK/HKD;292278994.08.17 08:12:55.807
0388.HK/HKD;292278994.08.17 08:12:55.807
0005.HK/HKD;292278994.08.17 08:12:55.807
0013.HK/HKD;292278994.08.17 08:12:55.807
1398.HK/HKD;292278994.08.17 08:12:55.807
0135.HK/HKD;292278994.08.17 08:12:55.807
0992.HK/HKD;292278994.08.17 08:12:55.807
0494.HK/HKD;292278994.08.17 08:12:55.807
0823.HK/HKD;292278994.08.17 08:12:55.807
0066.HK/HKD;292278994.08.17 08:12:55.807
0017.HK/HKD;292278994.08.17 08:12:55.807
0857.HK/HKD;292278994.08.17 08:12:55.807
2318.HK/HKD;292278994.08.17 08:12:55.807
0006.HK/HKD;292278994.08.17 08:12:55.807
1928.HK/HKD;292278994.08.17 08:12:55.807
0083.HK/HKD;292278994.08.17 08:12:55.807
0016.HK/HKD;292278994.08.17 08:12:55.807
0019.HK/HKD;292278994.08.17 08:12:55.807
0700.HK/HKD;292278994.08.17 08:12:55.807
0322.HK/HKD;292278994.08.17 08:12:55.807
0151.HK/HKD;292278994.08.17 08:12:55.807
0004.HK/HKD;292278994.08.17 08:12:55.807
WN.CA/CAD;292278994.08.17 08:12:55.807
ELD.CA/CAD;292278994.08.17 08:12:55.807
CNR.CA/CAD;292278994.08.17 08:12:55.807
COS.CA/CAD;292278994.08.17 08:12:55.807
ARX.CA/CAD;292278994.08.17 08:12:55.807
SLF.CA/CAD;292278994.08.17 08:12:55.807
CCO.CA/CAD;292278994.08.17 08:12:55.807
BAM-A.CA/CAD;292278994.08.17 08:12:55.807
SAP.CA/CAD;292278994.08.17 08:12:55.807
PPL.CA/CAD;292278994.08.17 08:12:55.807
FM.CA/CAD;292278994.08.17 08:12:55.807
GIL.CA/CAD;292278994.08.17 08:12:55.807
MFC.CA/CAD;292278994.08.17 08:12:55.807
CP.CA/CAD;292278994.08.17 08:12:55.807
MRU.CA/CAD;292278994.08.17 08:12:55.807
HSE.CA/CAD;292278994.08.17 08:12:55.807
BMO.CA/CAD;292278994.08.17 08:12:55.807
BNS.CA/CAD;292278994.08.17 08:12:55.807
CM.CA/CAD;292278994.08.17 08:12:55.807
NA.CA/CAD;292278994.08.17 08:12:55.807
TD.CA/CAD;292278994.08.17 08:12:55.807
CPG.CA/CAD;292278994.08.17 08:12:55.807
SU.CA/CAD;292278994.08.17 08:12:55.807
ABX.CA/CAD;292278994.08.17 08:12:55.807
BCE.CA/CAD;292278994.08.17 08:12:55.807
CCT.CA/CAD;292278994.08.17 08:12:55.807
CVE.CA/CAD;292278994.08.17 08:12:55.807
POT.CA/CAD;292278994.08.17 08:12:55.807
TRP.CA/CAD;292278994.08.17 08:12:55.807
VRX.CA/CAD;292278994.08.17 08:12:55.807
IMO.CA/CAD;292278994.08.17 08:12:55.807
POW.CA/CAD;292278994.08.17 08:12:55.807
ATD-B.CA/CAD;292278994.08.17 08:12:55.807
RY.CA/CAD;292278994.08.17 08:12:55.807
AEM.CA/CAD;292278994.08.17 08:12:55.807
BBD-B.CA/CAD;292278994.08.17 08:12:55.807
TLM.CA/CAD;292278994.08.17 08:12:55.807
CNQ.CA/CAD;292278994.08.17 08:12:55.807
CTC-A.CA/CAD;292278994.08.17 08:12:55.807
GIB-A.CA/CAD;292278994.08.17 08:12:55.807
QSR.CA/CAD;292278994.08.17 08:12:55.807
BB.CA/CAD;292278994.08.17 08:12:55.807
FTS.CA/CAD;292278994.08.17 08:12:55.807
ECA.CA/CAD;292278994.08.17 08:12:55.807
ENB.CA/CAD;292278994.08.17 08:12:55.807
MG.CA/CAD;292278994.08.17 08:12:55.807
SJR-B.CA/CAD;292278994.08.17 08:12:55.807
SNC.CA/CAD;292278994.08.17 08:12:55.807
TCK-B.CA/CAD;292278994.08.17 08:12:55.807
TRI.CA/CAD;292278994.08.17 08:12:55.807
AGU.CA/CAD;292278994.08.17 08:12:55.807
IPL.CA/CAD;292278994.08.17 08:12:55.807
RCI-B.CA/CAD;292278994.08.17 08:12:55.807
K.CA/CAD;292278994.08.17 08:12:55.807
TA.CA/CAD;292278994.08.17 08:12:55.807
YRI.CA/CAD;292278994.08.17 08:12:55.807
SLW.CA/CAD;292278994.08.17 08:12:55.807
DBS.SG/SGD;292278994.08.17 08:12:55.807
OCBC.SG/SGD;292278994.08.17 08:12:55.807
ST.SG/SGD;292278994.08.17 08:12:55.807
UOB.SG/SGD;292278994.08.17 08:12:55.807
JM.SG/SGD;292278994.08.17 08:12:55.807
KEP.SG/SGD;292278994.08.17 08:12:55.807
HKL.SG/SGD;292278994.08.17 08:12:55.807
JS.SG/SGD;292278994.08.17 08:12:55.807
CAPL.SG/SGD;292278994.08.17 08:12:55.807
GLP.SG/SGD;292278994.08.17 08:12:55.807
THBEV.SG/SGD;292278994.08.17 08:12:55.807
WIL.SG/SGD;292278994.08.17 08:12:55.807
SPH.SG/SGD;292278994.08.17 08:12:55.807
GENS.SG/SGD;292278994.08.17 08:12:55.807
SGX.SG/SGD;292278994.08.17 08:12:55.807
SIA.SG/SGD;292278994.08.17 08:12:55.807
CIT.SG/SGD;292278994.08.17 08:12:55.807
CD.SG/SGD;292278994.08.17 08:12:55.807
CT.SG/SGD;292278994.08.17 08:12:55.807
STE.SG/SGD;292278994.08.17 08:12:55.807
HPHT.SG/SGD;292278994.08.17 08:12:55.807
AREIT.SG/SGD;292278994.08.17 08:12:55.807
NOBL.SG/SGD;292278994.08.17 08:12:55.807
JCNC.SG/SGD;292278994.08.17 08:12:55.807
SCI.SG/SGD;292278994.08.17 08:12:55.807
GGR.SG/SGD;292278994.08.17 08:12:55.807
SMM.SG/SGD;292278994.08.17 08:12:55.807
STH.SG/SGD;292278994.08.17 08:12:55.807
SIE.SG/SGD;292278994.08.17 08:12:55.807
OLAM.SG/SGD;292278994.08.17 08:12:55.807
ADS.DE/EUR;2015.03.13 09:00:16.248
ALV.DE/EUR;2015.04.09 09:00:27.004
BAS.DE/EUR;2015.04.22 09:00:27.260
BAYN.DE/EUR;2015.03.20 09:00:11.003
BMW.DE/EUR;2015.03.24 09:00:27.027
BEI.DE/EUR;2015.04.08 09:00:13.023
CBK.DE/EUR;2015.03.26 09:00:16.027
CON.DE/EUR;2015.04.08 09:00:27.003
DAI.DE/EUR;2015.03.27 09:02:31.058
DBK.DE/EUR;2015.03.25 09:00:29.080
DB1.DE/EUR;2015.04.14 09:00:18.058
LHA.DE/EUR;2015.04.21 09:00:16.007
DPW.DE/EUR;2015.03.31 09:00:24.221
DTE.DE/EUR;2015.03.31 09:00:30.000
EOAN.DE/EUR;2015.04.20 09:00:28.095
FME.DE/EUR;2015.04.01 09:00:17.046
FRE.DE/EUR;2015.04.10 09:00:25.112
HEI.DE/EUR;2015.04.02 09:00:30.229
HEN3.DE/EUR;2015.04.21 09:00:12.128
IFX.DE/EUR;2015.04.13 09:00:12.186
SDF.DE/EUR;2015.04.15 09:00:08.089
LXS.DE/EUR;2015.04.21 09:00:13.046
LIN.DE/EUR;2015.04.21 09:00:04.108
MRK.DE/EUR;2015.03.24 09:00:14.130
MUV2.DE/EUR;2015.04.21 09:02:19.013
RWE.DE/EUR;2015.04.16 09:00:22.010
SAP.DE/EUR;2015.04.16 09:00:26.013
SIE.DE/EUR;2015.04.20 09:00:01.026
TKA.DE/EUR;2015.04.14 09:00:06.230
VOW3.DE/EUR;2015.04.14 09:00:21.092
DRW3.DE/EUR;292278994.08.17 08:12:55.807
DUE.DE/EUR;292278994.08.17 08:12:55.807
BOSS.DE/EUR;2015.04.09 09:02:07.157
PAH3.DE/EUR;2015.04.21 09:02:08.110
PSM.DE/EUR;2015.04.20 09:02:21.048
TUI1.DE/EUR;2015.04.15 09:02:21.055
VNA.DE/EUR;2015.04.14 09:02:17.186
AIR.FR/EUR;2016.09.30 11:34:32.866
ALU.FR/EUR;292278994.08.17 08:12:55.807
ALO.FR/EUR;2016.09.27 09:53:59.336
MTN.NL/EUR;292278994.08.17 08:12:55.807
CS.FR/EUR;2016.09.30 11:31:09.836
BNP.FR/EUR;2016.09.30 11:23:42.196
EN.FR/EUR;2016.09.30 11:31:09.230
CAP.FR/EUR;2016.09.30 11:31:09.534
CA.FR/EUR;2016.09.30 11:31:09.937
SGO.FR/EUR;2016.10.31 10:47:37.180
ML.FR/EUR;292278994.08.17 08:12:55.807
ACA.FR/EUR;2016.09.30 09:00:19.978
BN.FR/EUR;2016.09.30 11:23:42.399
EDF.FR/EUR;2016.09.30 11:31:25.470
EI.FR/EUR;2016.09.30 11:31:08.972
GSZ.FR/EUR;292278994.08.17 08:12:55.807
KER.FR/EUR;2016.09.30 11:31:09.332
OR.FR/EUR;2016.08.05 17:00:00.722
LG.FR/EUR;292278994.08.17 08:12:55.807
LR.FR/EUR;2016.08.05 16:50:11.216
MC.FR/EUR;2016.08.05 17:00:00.621
ORA.FR/EUR;2016.08.05 17:00:01.126
RI.FR/EUR;2016.08.05 17:00:00.924
PUB.FR/EUR;2016.08.05 17:00:01.330
RNO.FR/EUR;2016.08.08 09:00:15.715
SAF.FR/EUR;2016.08.05 17:00:05.268
SAN.FR/EUR;2016.08.05 17:00:00.520
SU.FR/EUR;2016.08.05 17:00:01.733
GLE.FR/EUR;2016.09.30 11:31:10.845
SOL.BL/EUR;292278994.08.17 08:12:55.807
TEC.FR/EUR;292278994.08.17 08:12:55.807
FP.FR/EUR;2016.09.30 11:31:09.129
UL.NA/EUR;292278994.08.17 08:12:55.807
FR.FR/EUR;2016.09.30 11:31:09.280
VIE.FR/EUR;2016.08.05 17:00:00.318
DG.FR/EUR;2016.09.30 11:31:14.172
VIV.FR/EUR;2016.08.05 17:00:00.521
UG.FR/EUR;2016.08.05 17:00:02.035
AC.FR/EUR;2016.08.11 10:59:52.334
AF.FR/EUR;2016.09.27 09:53:59.324
AI.FR/EUR;2016.09.30 10:06:30.108
LI.FR/EUR;2016.08.05 17:00:00.927
VK.FR/EUR;2016.08.05 17:00:05.369
ENGI.FR/EUR;2016.09.30 11:31:09.164
LHN.FR/EUR;292278994.08.17 08:12:55.807
ABBN.CH/CHF;2015.06.16 09:01:50.097
ADEN.CH/CHF;2015.06.16 09:01:50.091
CLN.CH/CHF;2015.06.16 09:01:51.006
CSGN.CH/CHF;2015.06.16 09:01:50.140
GIVN.CH/CHF;2015.06.16 09:01:50.223
BAER.CH/CHF;2015.06.16 05:45:00.109
KNIN.CH/CHF;2015.06.17 05:45:00.639
LHN.CH/CHF;2015.06.17 05:45:00.374
LONN.CH/CHF;2015.06.16 05:45:00.225
NESN.CH/CHF;2015.06.16 09:01:52.100
NOVN.CH/CHF;2015.06.16 09:01:51.059
ROG.CH/CHF;2015.07.03 09:00:16.063
SGSN.CH/CHF;2015.08.06 09:00:11.123
SIK.CH/CHF;2015.08.06 05:45:00.036
SOON.CH/CHF;2015.08.07 05:45:00.161
UHR.CH/CHF;2015.08.07 05:45:00.598
SLHN.CH/CHF;2015.08.06 09:00:11.069
SREN.CH/CHF;2015.08.06 09:00:11.033
SCMN.CH/CHF;2015.07.03 05:45:00.556
SYNN.CH/CHF;292278994.08.17 08:12:55.807
RIGN.CH/CHF;292278994.08.17 08:12:55.807
UBSG.CH/CHF;2015.06.15 09:00:43.072
ZURN.CH/CHF;2015.08.07 09:00:49.042
AAL.GB/GBX;2015.08.25 08:00:00.884
ANTO.GB/GBX;2016.09.06 09:00:11.108
ARM.GB/GBX;292278994.08.17 08:12:55.807
AHT.GB/GBX;2016.09.06 09:00:06.263
ABF.GB/GBX;2016.09.06 09:00:11.322
AZN.GB/GBX;2016.09.06 09:00:22.212
AV.GB/GBX;2016.09.06 09:00:10.112
BAB.GB/GBX;2016.09.06 09:00:26.612
BA.GB/GBX;2016.09.06 09:00:02.302
BARC.GB/GBX;2016.09.06 09:00:29.582
BG.GB/GBX;292278994.08.17 08:12:55.807
BLT.GB/GBX;2016.09.06 09:00:00.321
BP.GB/GBX;2016.09.06 09:00:11.431
BATS.GB/GBX;2016.09.06 09:00:28.156
BLND.GB/GBX;2016.09.06 09:00:26.942
BT.GB/GBX;2016.07.07 11:19:45.705
BNZL.GB/GBX;2016.09.06 09:00:26.502
BRBY.GB/GBX;2016.07.08 16:48:38.593
CPI.GB/GBX;2016.07.07 11:19:50.707
CCL.GB/GBX;2016.07.06 09:08:16.948
CAN.GB/GBX;292278994.08.17 08:12:55.807
CPG.GB/GBX;2016.07.08 16:48:50.716
CRH.GB/GBX;2017.01.05 09:02:03.422
CRDA.GB/GBX;2016.11.01 11:17:55.985
DGE.GB/GBX;2016.07.06 09:08:09.402
EZJ.GB/GBX;2016.07.08 16:49:03.589
EXPN.GB/GBX;2016.07.08 16:49:01.779
FRES.GB/GBX;2016.07.07 11:20:18.962
GFS.GB/GBX;2016.07.07 11:20:10.705
GKN.GB/GBX;292278994.08.17 08:12:55.807
GSK.GB/GBX;2016.07.06 09:00:45.442
GLEN.GB/GBX;2016.07.07 11:44:38.924
HMSO.GB/GBX;2016.07.07 11:20:09.823
HSBA.GB/GBX;2016.07.07 11:20:08.454
IMT.GB/GBX;2016.07.06 09:03:22.722
ISAT.GB/GBX;2016.07.08 16:49:38.819
IHG.GB/GBX;2016.11.01 09:37:29.422
ITRK.GB/GBX;2016.07.06 09:14:52.125
ITV.GB/GBX;2016.07.07 11:20:45.708
KGF.GB/GBX;2016.07.07 11:20:37.038
LAND.GB/GBX;2016.07.07 11:20:55.706
LGEN.GB/GBX;2016.07.07 11:20:45.708
LLOY.GB/GBX;2016.07.08 16:50:03.598
LSE.GB/GBX;2016.07.06 09:34:44.462
MKS.GB/GBX;2016.07.07 11:21:52.042
MNDI.GB/GBX;2016.07.08 16:50:16.087
NG.GB/GBX;2016.07.07 11:21:30.382
NXT.GB/GBX;2016.07.06 09:00:20.632
OML.GB/GBX;292278994.08.17 08:12:55.807
PSON.GB/GBX;2016.07.07 11:23:09.303
PSN.GB/GBX;2016.07.08 16:50:33.592
PFC.GB/GBX;2016.07.08 16:50:28.912
PRU.GB/GBX;2016.07.07 11:21:12.039
RRS.GB/GBX;2016.07.06 09:01:13.871
RB.GB/GBX;2016.07.06 09:03:30.228
REL.GB/GBX;2016.07.08 16:50:53.371
REX.GB/GBX;292278994.08.17 08:12:55.807
RIO.GB/GBX;2016.07.06 09:08:00.342
RR.GB/GBX;2016.07.08 16:51:03.596
RBS.GB/GBX;2016.07.08 13:42:35.340
RDSA.GB/GBX;292278994.08.17 08:12:55.807
RDSB.GB/GBX;2016.11.01 11:04:45.257
RMG.GB/GBX;2016.07.07 11:24:51.000
RSA.GB/GBX;2016.07.07 11:21:45.992
SAB.GB/GBX;292278994.08.17 08:12:55.807
SGE.GB/GBX;2016.07.08 16:51:23.596
SBRY.GB/GBX;2016.07.07 11:22:39.275
SVT.GB/GBX;2016.07.06 09:05:34.123
SHP.GB/GBX;2016.07.06 09:01:14.404
SKY.GB/GBX;2016.07.07 11:22:29.817
SN.GB/GBX;2016.07.08 16:51:42.485
SMIN.GB/GBX;2016.07.08 16:51:38.466
SSE.GB/GBX;2016.07.08 16:51:48.490
STAN.GB/GBX;2016.07.07 11:22:15.996
SL.GB/GBX;292278994.08.17 08:12:55.807
TATE.GB/GBX;2016.07.08 16:51:53.691
TSCO.GB/GBX;2016.07.08 16:52:03.507
TPK.GB/GBX;2016.07.08 16:52:02.999
TLW.GB/GBX;2016.07.07 11:22:26.108
ULVR.GB/GBX;2016.07.06 09:02:51.642
UU.GB/GBX;2016.07.08 17:02:48.215
VOD.GB/GBX;2016.07.07 11:22:48.552
WEIR.GB/GBX;2016.07.08 16:52:20.729
WTB.GB/GBX;2016.07.06 09:09:30.246
MRW.GB/GBX;2016.07.07 11:22:39.273
WOS.GB/GBX;2016.07.06 09:08:57.085
WPP.GB/GBX;2016.07.08 14:41:45.460
ADN.GB/GBX;292278994.08.17 08:12:55.807
ADM.GB/GBX;2016.09.06 09:00:06.151
AGK.GB/GBX;2016.09.06 09:00:28.482
IAG.GB/GBX;2016.11.08 14:50:55.229
CNA.GB/GBX;2016.07.07 11:19:47.034
EBS.AT/EUR;2016.11.15 09:27:59.759
IIA.AT/EUR;292278994.08.17 08:12:55.807
RBI.AT/EUR;2016.11.15 09:28:00.076
VOE.AT/EUR;2016.11.15 09:27:58.433
ABI.BE/EUR;2016.11.21 09:00:06.376
AGS.BE/EUR;2016.11.21 09:00:06.391
BELG.BE/EUR;2016.11.07 09:02:01.221
KBC.BE/EUR;2016.11.07 09:01:01.234
SOLB.BE/EUR;2016.11.07 09:01:05.070
UCB.BE/EUR;2016.11.07 09:01:58.189
UMI.BE/EUR;2016.11.07 09:01:02.346
CARLB.DK/DKK;2016.11.08 09:00:03.065
COLOB.DK/DKK;2016.11.08 09:00:04.171
DANSKE.DK/DKK;2016.11.08 14:51:41.538
MAERSKB.DK/DKK;2016.11.08 15:36:37.318
NOVOB.DK/DKK;2016.11.08 09:01:00.667
NZYMB.DK/DKK;2016.11.08 09:01:05.718
PNDORA.DK/DKK;2016.11.08 15:36:49.486
VWS.DK/DKK;2016.11.08 09:01:02.171
ELI1V.FI/EUR;2016.11.03 09:00:04.659
NES1V.FI/EUR;2016.11.03 09:02:00.653
NRE1V.FI/EUR;2016.11.03 09:02:00.856
OUT1V.FI/EUR;2016.11.03 09:03:24.813
OTE1V.FI/EUR;2016.11.03 09:00:01.431
STERV.FI/EUR;2016.11.03 09:00:03.652
TLS1V.FI/EUR;2016.11.09 10:14:30.145
AGN.NL/EUR;2016.11.14 12:24:13.526
AH.NL/EUR;2016.11.14 12:24:13.021
AKZA.NL/EUR;2016.11.14 12:24:13.526
ASML.NL/EUR;2016.11.14 12:24:13.729
DSM.NL/EUR;2016.11.14 12:24:13.223
GTO.NL/EUR;2016.11.14 12:24:13.021
HEIA.NL/EUR;2016.11.14 12:24:14.502
INGA.NL/EUR;2016.11.14 12:24:13.672
KPN.NL/EUR;2016.11.14 12:24:21.288
MT.NL/EUR;2016.11.14 12:24:13.070
PHIA.NL/EUR;2016.11.09 15:27:19.825
RAND.NL/EUR;2016.11.14 12:24:34.512
RDSA.NL/EUR;2016.11.14 12:24:13.671
REN.NL/EUR;2016.11.14 12:24:13.021
UL.NL/EUR;292278994.08.17 08:12:55.807
UNA.NL/EUR;2016.11.14 12:24:13.069
VPK.NL/EUR;2016.11.14 12:24:14.177
WKL.NL/EUR;2016.11.14 12:24:13.527
DNB.NO/NOK;2016.11.14 12:25:59.015
FRO.NO/NOK;292278994.08.17 08:12:55.807
MHG.NO/NOK;2016.11.14 12:26:00.898
NHY.NO/NOK;2016.11.14 12:25:59.089
ORK.NO/NOK;2016.11.14 12:25:58.910
STL.NO/NOK;2016.11.14 12:25:59.308
TEL.NO/NOK;2016.11.14 12:26:39.306
YAR.NO/NOK;292278994.08.17 08:12:55.807
EDP.PT/EUR;2016.11.14 16:55:01.825
GALP.PT/EUR;2016.11.14 16:55:01.009
ABE.ES/EUR;292278994.08.17 08:12:55.807
ACS.ES/EUR;2016.11.14 12:23:20.562
ACX.ES/EUR;2016.11.14 12:23:18.558
AENA.ES/EUR;2016.11.14 12:23:18.962
AMS.ES/EUR;2016.11.14 12:23:28.687
BBVA.ES/EUR;2016.11.14 12:23:14.051
CABK.ES/EUR;2016.11.14 12:23:16.354
DIA.ES/EUR;2016.11.14 12:24:03.549
ELE.ES/EUR;2016.11.14 12:23:18.461
ENG.ES/EUR;2016.11.14 12:23:13.650
FER.ES/EUR;2016.11.14 12:23:12.349
GAM.ES/EUR;2016.11.14 12:23:13.149
GAS.ES/EUR;2016.11.14 12:23:15.989
IBE.ES/EUR;2016.11.14 12:23:15.653
ITX.ES/EUR;2016.11.14 12:23:13.750
REE.ES/EUR;2016.11.14 12:23:34.088
REP.ES/EUR;2016.11.14 12:23:14.952
SAB.ES/EUR;292278994.08.17 08:12:55.807
SAN.ES/EUR;2016.11.14 12:23:12.749
TEF.ES/EUR;2016.11.14 12:23:23.370
ABB.SE/SEK;2016.11.14 17:09:04.708
ALFA.SE/SEK;2016.11.07 09:01:35.856
ATCOA.SE/SEK;2016.11.14 17:09:03.402
AZN.SE/SEK;292278994.08.17 08:12:55.807
ELUXB.SE/SEK;2016.11.07 09:01:01.177
ERICB.SE/SEK;2016.11.14 17:09:02.210
GETIB.SE/SEK;2016.11.07 09:01:05.356
HMB.SE/SEK;2016.11.07 09:01:34.373
INVEB.SE/SEK;2016.11.14 17:09:08.695
NDA.SE/SEK;2016.11.07 09:01:06.017
SAND.SE/SEK;2016.11.07 09:01:02.610
SCAB.SE/SEK;2016.11.07 09:01:00.847
SEBA.SE/SEK;2016.11.14 17:09:02.218
SECUB.SE/SEK;2016.11.07 09:01:21.856
SKAB.SE/SEK;2016.11.07 09:01:21.306
SKFB.SE/SEK;2016.11.07 09:01:00.959
SWEDA.SE/SEK;2016.11.07 09:01:59.843
SWMA.SE/SEK;2016.11.07 09:01:05.249
TEL2B.SE/SEK;2016.11.07 09:01:03.818
TLSN.SE/SEK;2016.11.14 17:09:02.722
VOLVB.SE/SEK;2016.11.07 09:01:18.337
Haeggor
Post by Haeggor »
And keep in mind all instruments that have no TICK data should not appear in my last posts lists, but could have data in other timeframes.
Also, higher timeframes may start earlier back in time - EURUSD for example goes back to 1973 in the weekly timeframe. I guess that is not relevant for Tickstory, but I wanted to mention it just in case.
Haeggor
Post by Haeggor »
Going over the data it seems like the starting dates dukascopy's api gave me may not even be the earliest dates possible. I.e. :
AUD/SGD;2007.03.14 01:00:20.923 was the data from the jforex api, however, I was able to download data starting at 2007.02.14 00:00 with Tickstory (looking at the directories with data in it) by selecting a way earlier date.
Interestingly though, Tickstory also reports 2007.03.14 in the table as starting date.
I know that the earliest data probably is not too reliable for backtesting, but for the sake of completion I thought I should mention it.
John86045
Post by John86045 »
thanks
Hi Haeggor,
Thank you very much for your contribution! We'll use this to cross-check some of the instruments/dates we have listed. Interesting to note that on occasion, Dukascopy will extend the coverage of their tick data to an earlier date. , so we do need to review them and users are often the best source of feedback!
Thanks again.
