Single-user, 2 Installations
volpiemanuele
Post by volpiemanuele »
HI,
what measn Single-user, 2 Installations....Can I install tickstory in two different pc with the same code that I will purchase ?
Thnaks
Emanuele
Re: Single-user, 2 Installations
Hi Emanuele,
That is correct. Your singer-user license key allows you to install on two different PCs/VMs that you own. Any additional PCs or users will require an additional license accordingly.
