Downloaded data to online database like openml
tickstudent
Hi! I am using this data for educational purposes. At the end of my research I will write a thesis on the subject of AI trading. Is it possible to store this data in an open online database like openml.org, so other researchers can understand with what data I wrote my thesis and how I used the data in the algorithms?
Re: Downloaded data to online database like openml
Hi Tickstudent,
If the software application you mention allows importing data in CSV/Tab/File format then you should be able to integrate with it.
