FXT Sizing
Tony
FXT Sizing
Post by Tony »
Why the size of FXT file of Tickstory different from using CSV2FXT form eareview.net so much and completely different back test result when using the same period of time?
Re: FXT Sizing
Hi Tony,
Did you happen to select "filter duplicate ticks" or other relevant option?
Tony
Re: FXT Sizing
Post by Tony »
Every file that use csv2fxt is larger than tickstory's.
I try use the same as I can set but the size is completely different and the result too.
Is tickstory can use specific csv tick data from my computer?
Re: FXT Sizing
Hi Tony,
If you wish to compare the rows of your CSV export vs Tickstory, you can use the 'Export to File' option.
