Export Ticks to CSV
Graham
Export Ticks to CSV
Post by Graham »
Thanks for a great product.
I am exporting data from your database to a CSV file for input into ForexTester.
When the output format is for tick level data, the file just contains the same timestamp and priceinfo. If I export the same data to 1-second format, it exports fine.
If I export tick data, I get this (even when selecting earlier date range) which is the timestamp of the time of export:
20130704 16:05:24 1.20112 1.2034 1.2001 1.2033 1.3
Help appreciated.
Cheers.
Re: Export Ticks to CSV
Hi Graham,
The reason why you are seeing the incorrect time-stamp for tick data is most likely because you are using the incorrect "time stamp" token.
{BarBeginTime} is specifically used to output the begin time of the candle, and what you are after is the {Timestamp} of the tick.
Please consult the help topic here for further details:
http://www.tickstory.com/help/tickstory ... m_form.htm
If you would like us to have a pre-defined value for ForexTester, please let us know the format and we can include it in the next release.
