Launch problem build 1170
RomanZif
Post by RomanZif »
Hi, help me pls
had tried to launch mt4 for backtest
After 3 sec i have this msg
Working on MacOS 10.14.6
Using PlayOnMac 4.3.3
yesterday everything working perfect.
But today cant launch (((
Re: Launch problem build 1170
Hi RomanZif,
Metatrader have pushed through an update for Build 1210. If you have an active subscription, you can download v1.9.5 that supports this new version.
If you are currently using Lite, then we will be issuing an update soon.
RomanZif
Post by RomanZif »
But my versions is 1170
Hi Romanzif,
I'm guessing something on your system has changed if it was previously working.
Please try to go through the trouble-shooting steps for the launcher here:
https://tickstory.com/help/tickstorylit ... cher_error
We're not familiar with the Mac emulator you are using, so if you have a native PC you might want to try it there as the launcher does support 1170.
