Hi all,
looking for a step by step description how to import real ticks to MT5. The video did not help.
TRYING TO IMPORT CSV but mt5 ask only option .json
thanks
Bernhard
Tick data import to MT5
Re: Tick data import to MT5
Hi Bernhard,
The window you are showing is to "Creating a custom symbol" and the "import" option you selected is to import the symbol settings (in .json format).
Once you have created your symbol, you can select it and there is a button called "Import ticks" which will allow you to import the tick data for it.
Here is a step-by-step guide on how to import tick data (and also bar data) into Metatrader 5:
https://tickstory.com/how-to-import-tic ... atrader-5/
Hi buddy, can you kind check the link, showing "resolving host", I guess it is down. Not sure do check once.tickstory wrote:Hi Bernhard,
Regards,
Sloth Smith
We've just checked the URL and it's working fine. Please try again, it may have been a temporary glitch on our or your side.
