I had to reinstall my Tickstory Lite 1.9.5.1, after that the new installed TS Lite doesn't "see" tick data downloaded w. previous installation.
Folders for program and the data are the same.
How could I fix it or should I download all tick data again ?
T.Lite 1.9.5.1 doesn't "see" tick data downloaded earlier
advanceduser
Re: T.Lite 1.9.5.1 doesn't "see" tick data downloaded earlie
Hi Advanceduser,
Do you have a screenshot of what you are seeing? Are you referring to the Dukascopy tick data "begin" and "end" dates not showing any more after upgrade? If so, make sure the Dukascopy "Store Folder" is pointing to the location of your Dukascopy data and this should address the issue.
advanceduser
Thank you for fast response!
Was sick a little bit, didn't use PC for a few days...
advanceduser
Please don't take in account my previous post - I messed up something (my stupidity...) changing data folder locations 3 times , on external HDD too.
So I reinstalled correctly TS once again and everything works fine.
